Category: Milling
Milling
VM3018
Milling
BR Series Bridge Mills, General Purpose VM Series vertical Machining Centers, Performance IL Series Vertical Machining Centers, Performance XP Series Vertical Machining Centers, and Tool Room Mills
5-Axis Vertical Machining Center
The most compact machining center in Milltronics’ 5-axis line, the VM200-5X has X, Y, Z travels of 21 x 16 x 19 inches. Its rotary table offers +30°/-110° of A-axis rotation and 360° in the C-axis. This vertical, linear way machining center features a 10,000-RPM, BIGPLUS® ISO No. 40 spindle and a 24-tool ATC. Machinists will love its INSPIRE+ control, which provides improved surface finish and cycle times, an advanced proprietary motion engine, and a 19-inch, color, LCD touch screen.
The VM250IL-5X is the largest of Milltronics’ 5-axis machining centers with X, Y, Z travels of 30 x 20 x 20.5 inches. Its rotary table offers +30°/-110° of A-axis rotation and 360° in the C-axis. This vertical, linear way machining center features a 12,000-RPM, BIGPLUS® ISO No. 40 spindle and a 40-tool ATC. An added benefit is its user-friendly INSPIRE+ control, which provides improved surface finish and cycle times, an advanced proprietary motion engine, and a 19-inch, color, LCD touch screen.
Bridge Mill
Our most popular BR Series bridge mill CNC machine at 150″ x 60″ x 28″, the high-speed BR6150IL has a 60″ x 150″ table and a 24 HP dual wound 10,000 RPM #40 taper BIG-PLUS? inline spindle. Available with an optional full enclosure and/or a 24 station tool changer.
Tool Room Mill
The VK4II is a full 3-Axis CNC knee mill with the unique Milltronics MillSlideTM that provides greater rigidity and more spindle nose to table top than conventional knee mills. With 33″ x 14.25″ x 5.25″ (MillSlideTM), 16.5″ knee and 5.83″ quill travel, the VK4II can be run as manual, teach or full CNC.
Tool Room Mill
The TRM3016 is a tool room mill that offers large travels, speed and power at a great price. A unique feature of the TRM Series is the “drop down” door openings that allow long part pass through to help accommodate oversize parts.
Tool Room Mill
The TRQ20 is designed for versatility and precision, featuring a robust Meehanite cast iron frame and heavily ribbed castings for superior dampening during high-speed machining. Its 54″ x 16″, precision-ground table is supported by hardened and ground square box ways with Turcite surfaces to maintain accuracy and eliminate deformation.
The 4.125″ quill with 6″ of travel, CT40 taper, and ±15/45 tilting head provides exceptional flexibility. A belt-driven spindle with an 8:1 back gear delivers high torque for demanding applications, while a powered drawbar ensures secure tool retention. High-precision ballscrews and belt-driven AC servo motors maximize performance and reliability, making the TRQ20 ideal for a range of machining needs.
3-Axis Vertical Machining Center
The Milltronics VM2515 has 25″ x 15″ x 20″ travels and a 30″ x 16″ table that supports 3,140 lbs table weight at full speed. The VM2515 has a 15 HP 10,000 RPM BIG-PLUS® spindle.
With a 34″ x 18″ table (table width matches the Y-travel) this 30″ x 18″ x 20″ CNC mill packs a 20 HP spindle motor and 10,000 RPM BIG-PLUS® spindle and more.
Our most popular size CNC mill, the Milltronics VM4020 gives you 40″ x 20″ x 20″ travels, a 46″ x 20″ table, a 20 HP spindle motor, 10,000 RPM BIG-PLUS® spindle and much more.
For only a few dollars more than the VM4020, the VM5020 CNC mill adds 10″ more X-travel. With a 52″ x 20″ table and travels of 50″ x 20″ x 20″ this machine is a great value.
Built with extra Z-clearance needed for tall parts or rotary fixtures, the VM5020EZ CNC mill is equipped with the Milltronics INSPIRE+ control supporting the ChipBoss™ machining cycle.
Get a Custom Quote within Minutes
Pick your Milltronics CNC Machine and any additional options to receive pricing in just a few easy steps!
