ChipBoss™ Software Feature
Optional software feature from Milltronics uses proprietary algorithms to calculate toolpaths and control the maximum allowable cutter engagement, resulting in:
- Faster cycle times — reduced by as much as 50% (or more).
- Better tool life — extends life by 3-5 times.
- More accurate parts via reduction in tool deflection.
ChipBoss™ uses trochoidal milling strategies with deeper depths of cut and smaller stepovers.
- Feed rates can be much higher than what conversational users are used to experiencing.
- Reduces the number of times a machine needs to accelerate and decelerate – less wear and tear.
- Includes Rest Roughing – automatically calculates areas to be machined and uses a smaller cutter to get just those areas that can’t be cut with larger tool, saving even more time.
How ChipBoss™ Works
A typical conversational program requires multiple incremental depth cuts at slower feeds and speeds throughout the entire program to account for the program’s tightest pockets and highest-pressure areas. However, ChipBoss™ utilizes constant engagement techniques, such as trochoidal milling, and calculates a more efficient toolpath based on the selected amount of radial tool engagement. Constant engagement techniques within the program’s tightest pockets and highest-pressure areas allow for deeper cuts and higher speeds and feeds throughout the program.
Rest Roughing
Use Rest Roughing to further improve cycle times:
- Select a large diameter tool to efficiently remove bulk material, followed by a smaller diameter tool to get what the larger tool can’t reach.
- Rest cycle does just the “rest” areas, no need to re-cut entire profile
- All automatic – just select from dropdown menu, and the software calculates everything for you.
Milltronics Shop View
Machine monitoring, communications and diagnostics at the tips of your fingers. With Milltronics Shop View (MSV) you have instant access to your machine’s status including programs, set-ups, digital readout, live snap shots of machine cutting video, spindle load, spindle hours, machine events log, file transfers, alarms and more— even when you’re not there!
MSV uses advanced cloud based monitoring, communication and diagnostics technology through an internet connection to your machine.
MSV is conveniently hosted in the cloud by Milltronics servers and eliminates the need of extensive IT infrastructure or expertise at your shop. All you need to do is point your PC, tablet or smart phone to msv.milltronics.com. The MSV platform is hosted on a secure network which users are able to log in and access their account through a responsive website with end-to-end encryption.MSV is compatible with Milltronics 9000 Series CNC controls or 8200-B
Features
- Industry 4.0 and MTConnect compliant
- Sortable and searchable dashboard list for quick selection
- Machine dashboard shows live data
- Tab view allows enlarged images/videos of screens
- Searchable machine file directory, registry and event logs
- Machine settings allow a user defined name to be entered to easily identify program or part running
Digital Setup Assistant
Optional Software Feature FAQ
Digital Set-Up Assistant (DSA) uses Wi-Fi to make a cell phone or tablet an extension of the user’s control. This optional software feature allows an operator to reduce setup time by easily accessing photos of parts and workholding, set-up data, tooling info and more.
How does DSA improve efficiency?
- Users can easily document part setup instructions for others to reference.
- Stores part-related files grouped as packages for easy recall.
- Packages associated with selected parts are automatically recalled and displayed.
- Part Setup Information is readily available on hand-held device.
What kind of information does DSA store and display?
User Generated
- Textual Notes
- Photos/Images
- Videos
- PDFs
Automatically Generated
- 3D Solid model rendering of finished part
- Run statistics
- Tools used in the part program
- Part Program Edit and Run history
How does DSA differ from MSV?
Assist in Setting up Parts
- Part-Centric Information
- Peer-to-Peer Intranet Networking
- App-Based
View the Status of Machines in your Shop
- Machine-Centric Information
- Cloud-Based Internet Networking
- Web-Based
Bi-Directional Turning Cycle
Milltronics Bi-Direction Conversational Turning:
- Improving productivity by up to 60%
- Increases tool life.
- Improves surface finish.
Improve turning speed and efficiency while taking advantage of the latest insert technology allowing for cutting forward and reverse, down to and up from.
Your Milltronics Control on the Cutting Edge!
