2920 Fortune Circle West | Suite C | Indianapolis, IN 46241, U.S.A
Milltronics CNC Control
[et_pb_section bb_built=”1″ admin_label=”section” transparent_background_fb=”default” _builder_version=”3.0.51″][et_pb_row admin_label=”Row” background_position=”top_left” background_repeat=”repeat” background_size=”initial”][et_pb_column type=”4_4″][et_pb_text admin_label=”Text” _builder_version=”3.0.51″ background_layout=”light” text_orientation=”left” border_style=”solid”]
Intuitive yet Powerful
[/et_pb_text][/et_pb_column][/et_pb_row][et_pb_row admin_label=”row” _builder_version=”3.0.47″ background_size=”initial” background_position=”top_left” background_repeat=”repeat”][et_pb_column type=”4_4″][et_pb_text admin_label=”Text” _builder_version=”3.0.51″ background_size=”initial” background_position=”top_left” background_repeat=”repeat” background_layout=”light” text_orientation=”left” border_style=”solid”]
At Milltronics, we are constantly refining our controls to simplify operation, shorten setup times, and provide features that reduce cycle times. The 9000-DGI Series control features 120 GB disk storage, 4GB memory, up to 10-times better graphic performance, mid-travel tactile keys, and an enlarged 15″ LCD touch screen. It’s a Windows®-based platform and offers all the user-friendly features that Milltronics CNC controls are known for, such as the G-code visualization screen.
[/et_pb_text][et_pb_divider admin_label=”Divider” _builder_version=”3.0.51″ divider_style=”solid” divider_position=”top” hide_on_mobile=”on” /][et_pb_video admin_label=”Video” _builder_version=”3.0.51″ src=”https://www.youtube.com/watch?v=mNQThcNYrwI” /][/et_pb_column][/et_pb_row][et_pb_row admin_label=”Row” background_position=”top_left” background_repeat=”repeat” background_size=”initial” _builder_version=”3.0.51″ background_position_1=”top_left” background_repeat_1=”no-repeat” background_position_2=”top_left” background_repeat_2=”no-repeat” make_fullwidth=”on”][et_pb_column type=”1_2″][et_pb_text admin_label=”Text” _builder_version=”3.0.51″ background_layout=”light” text_orientation=”left” border_style=”solid”]
INTUITIVE
With its conversational programming, on screen help, intuitive menus, color graphics, and prompted tool settings, the 9000-DGI CNC helps new operators get up to speed quickly. The 9000-DGI CNC makes it the one machine in the shop that everyone wants to operate.
EFFICIENT
The 9000-DGI CNC is packed with features that allow quick and confident operation of the CNC:
  • Solid model graphics allow the operator to see a completed part prior to cutting.
  • Mid program restart allows the operator to start anywhere in a program by verifying the graphics and then switching to Run Mode. It’s simple – no need for G&M code expertise!
  • Handwheel run allows the operator to run a program in a controlled mode where motion only
    occurs while the handwheel is turning. This feature allows operators to verify programs with total control and complete confidence.
[/et_pb_text][/et_pb_column][et_pb_column type=”1_2″][et_pb_text admin_label=”Text” _builder_version=”3.0.51″ background_layout=”light” text_orientation=”left” border_style=”solid”]
POWERFUL
  • The 9000-DGI CNC features a dual-core processor and high-speed motion control that is capable of executing 3,000 blocks per second. Execute the most demanding programs in the shortest time.
  • The 9000-DGI CNC is equipped with a 120 GB solid state drive, 4 GB RAM memory, USB ports and
    Ethernet connectivity.
PRODUCTIVE
The 9000-DGI CNC allows operators to run parts programmed conversationally or tool paths
generated by a CAM system. Coupled with a superfast motion control system, feature-packed CNC, and an interface designed to expedite setup and operation, the 9000-DGI CNC is the solution to helping your operator make parts faster and better.
[/et_pb_text][/et_pb_column][/et_pb_row][et_pb_row admin_label=”Row” background_position=”top_left” background_repeat=”repeat” background_size=”initial” _builder_version=”3.0.51″ background_position_1=”top_left” background_repeat_1=”no-repeat” make_fullwidth=”on”][et_pb_column type=”4_4″][et_pb_text admin_label=”Text” _builder_version=”3.0.51″ background_layout=”light” text_orientation=”left” border_style=”solid”]
Milltronics CNC Control Features
[metaslider id=7148]
[/et_pb_text][/et_pb_column][/et_pb_row][/et_pb_section][et_pb_section bb_built=”1″ admin_label=”Features” transparent_background_fb=”default” _builder_version=”3.0.51″ use_background_color_gradient=”on” background_color_gradient_start=”rgba(112,161,193,0)” background_color_gradient_end=”rgba(12,113,195,0.08)” transparent_background=”on”][et_pb_row admin_label=”Row” background_position=”top_left” background_repeat=”repeat” background_size=”initial”][et_pb_column type=”4_4″][et_pb_text admin_label=”Text” _builder_version=”3.0.51″ background_layout=”light” text_orientation=”left” border_style=”solid”]
PROGRAMMING FEATURES
[/et_pb_text][/et_pb_column][/et_pb_row][et_pb_row admin_label=”Features” background_position=”top_left” background_repeat=”repeat” background_size=”initial” _builder_version=”3.0.51″ background_position_1=”top_left” background_repeat_1=”no-repeat” background_position_2=”top_left” background_repeat_2=”no-repeat” make_fullwidth=”on” background_color_gradient_start=”rgba(234,234,234,0.62)” background_color_gradient_end=”rgba(232,232,232,0.43)” custom_padding=”20px|20px|20px|20px” collapsed=”off”][et_pb_column type=”1_2″][et_pb_text admin_label=”Text” _builder_version=”3.0.51″ background_layout=”light” text_orientation=”left” border_style=”solid”]
CONVERSATIONAL PROGRAMMING
  • Subprogram Call, Looping & Nesting
  • Thread Milling Cycle
  • Drill, Tap & Bore Cycles
  • ChipBoss™ Software
  • Tapered & Round Walls
  • Circular Framing Cycle
  • Custom Drill Cycle
  • DXF & IGES File Import
TRIG HELP FEATURES
  • Rectangular Framing Cycle
  • Rotary Axis Cylindrical Mapping
  • Math Function Input Fields
  • Arc & Line Intersection Find
  • Polygon Framing Cycle
  • 3D Sweep Routine
  • Custom Conversational Screens
  • Tangent Line & Arc Functions
  • Circular Pocket Cycle
  • Irregular Pocket Clear with Islands
  • Speed & Feed Calculator
  • 3 Point Arc Generation
  • Rectangular Pocket Cycle
G&M CODE PROGRAMMING
  • Prompting Help Screens
  • Line Extend Back
  • Polygon Pocket Cycle
  • Macro Programming
  • Concurrent Programming
  • Cartesian & Polar Coordinates
  • Slot Cycle
  • MDI
  • Cutter Compensation
  • Corner Chamfering & Rounding
  • Facing Cycle
  • EIA / ISO Code (Fanuc™) Compatibility
  • Inch / Metric
SINGLE PAGE AUTO-ROUTINES
  • Engraving with Serializing
  • Macro Variable Programming
  • Mirror, Scale & Rotate
  • Bolt Pattern, Drill, Tap & Bore Cycles
CANNED CYCLES
  • Dwell
  • Text Engraving on Arc or Line
  • Milling Cycles
OPERATIONAL FEATURES
RUN & VERIFY FEATURES
  • Continuous & Incremental Axis Jog
  • Feed Per Rev, Minute, Inverse Time
EDIT FEATURES
  • Handwheel Run
  • Electronic Handwheel(s)
  • Custom I/O Screens
  • Background Editing
  • Dry Run
  • Optional Probe & Tool Setter
  • Surface Finish Selection (SFS)
  • Cut, Copy, Paste & Move Editing
  • Block Skip, Optional Stop, Programmable Stop & Single Block
  • 199 Tool Diameter Length & Wear Offsets
  • Aux Keyboard Port
  • Handwheel through Text
  • Multiple Mid Program Start Options
  • DRO Measure
  • Networking
  • Overwrite & Insert
  • Mill Away / Jog Away
  • Safe Zone
  • Calculator
  • Global Find & Replace
  • Program Halt & Resume
  • Hot Keys
  • Service Diagnostics
  • Printout a Program (DGI Desktop)
  • Tool Load Monitoring
CONTROL FEATURES
  • Parts Counter
DISPLAY FEATURES
  • Tool Breakage Detection with Optional Tool Setter
  • Optional Four & Five Axis Simultaneous
  • Program/Parameter (Edit Key)
  • 3D Part & Wire Frame Tool Path Graphics
  • Estimated Cycle Time
  • 3000 Blocks/Second High Speed Processor
  • Remote Diagnostics
  • Color Graphics – Tool Path & Part Profile
  • 10%, 100% & Variable Rapid Override Select
  • Absolute / Incremental
  • Rigid Tapping
  • Solid Model Graphics
  • Spindle Load Meter
  • 120 GB Solid State Hard Drive
  • Selectable Corner Accuracy
  • Wireframe over Solids
  • Fine Tune Feed & Spindle Override
  • 4 GB Ram Memory
  • Selectable Languages
  • Transparent Graphics
  • Machine Status Light
  • 500 MB Text Editing with Cut, Copy, Move, Search & Replace
  • Handwheel Scroll through Menus
  • Customizable DRO
  • Programmable Air, Mist & Coolant
  • Ball Screw Pitch Error Correction
  • 15˝ Color LCD Touch Screen Display
  • User Definable Image Display Window
SET-UP FEATURES
  • True S Curve Acceleration & Jerk Correction
  • Automatic Homing
  • User Selectable Graphics in all Planes
  • Digital Setup Assistant (DSA)
  • Feed Forward Error Correction
  • Two USB Ports
  • Automatic Tool Setting Program
  • Full Language Error Messages
  • Hour Meter
  • Single Button Tool / Fixture Offset Entry
  • Backlash Compensation
  • Bi-Directional Turning Cycle
  • 60 Work Coordinates
  • Linear, Circular, Helical & Interpolation
  • Milltronics Shop View (MSV)
[/et_pb_text][/et_pb_column][/et_pb_row][/et_pb_section][et_pb_section bb_built=”1″ admin_label=”section” transparent_background_fb=”default” _builder_version=”3.0.51″ background_color_gradient_start=”rgba(12,113,195,0.17)” background_color_gradient_end=”rgba(12,113,195,0.32)” transparent_background=”on”][et_pb_row admin_label=”Row” background_position=”top_left” background_repeat=”repeat” background_size=”initial”][et_pb_column type=”4_4″][et_pb_text admin_label=”Text” _builder_version=”3.0.51″ background_layout=”light” text_orientation=”left” border_style=”solid”]
9000-DGI SERIES CONTROL HARDWARE SPECIFICATIONS
Milltronics 9000 Series CNC Control
9000 Series Control Brochure
ESSENTIALS
PROCESSOR INTEL® CORE I5-3610ME
INSTRUCTION SET 64-BIT
PERFORMANCE
NUMBER OF CORES 2
PROCESSOR BASE FREQUENCY 2.7 GHZ
MAX TURBO FREQUENCY 3.3 GHZ
MEMORY SPECIFICATIONS
DATA STORAGE 120 GB
SYSTEM MEMORY INSTALLED 4 GB
GRAPHICS SPECIFICATIONS
GPU CORE SPEED 600MHZ
MEMORY 1024 MB
OPERATING SYSTEM
PRIMARY OS WINDOWS® EMBEDDED 7
REAL TIME EXTENSION INTERVALZERO RTX
DISPLAY
SIZE 15″
RESOLUTION 1024 x 768
BACKLIGHT TYPE LED
TOUCHSCREEN RESISTIVE
OPERATOR PANEL
KEYPAD TYPE ABS MID-TRAVEL WITH TACTILE
FEEDBACK
DATA TRANSFER USB PORTS AND ETHERNET CONNECTIVITY
