[et_pb_section admin_label=”section”]
[et_pb_row admin_label=”row”]
[et_pb_column type=”4_4″]
[et_pb_text admin_label=”Text”]
The Milltronics BR Series bridge mills are fast machines in between a CNC router and a heavy-duty cast bridge mill. With speeds of up to 1,000 IPM, BR Series mills are built with linear cross roller guides, 24 HP 40 taper BIG-PLUS® inline spindles (either 10,000 or 15,000 RPM), and massive travels. Six different sizes are available up to 200″ in X-travel by 80″ in Y-travel. No special foundation is required, making for quick and affordable installation. Popular in high-speed applications such as aluminum, metal fabrications, plastics, wood patterns, and other large parts, the BR Series bridge mills are a faster and more affordable alternative to heavy-duty cast bridge mills.
[/et_pb_text]
[/et_pb_column]
[/et_pb_row]
[/et_pb_section]
