Improving Chip Management to Reduce Maintenance
How much additional revenue and profit could you generate if your shop gained eight days of production each year? Even better, what if you were picking up those eight days because you significantly reduced the amount of time spent on a nasty, grueling bit of manual labor that nobody likes performing? If you’re not already using a filtering chip conveyor, these benefits may be within your reach and easy to obtain.
by Don Hammer - Vice President
CNC Conveyor
For many applications, standard chip conveyors are perfectly adequate. If you’re only machining heavier materials and creating big, chunky chips, there’s a good chance you’re fine sticking with a standard solution. But a standard conveyor is likely to create some headaches if you’re machining aluminum or other materials that produce lighter chips, or if you’re working with graphite or castings that result in fine particles that create sludge.
When coolant empties from your work area into the dirty portion of your tank, lighter chips and small particulate matter can float. Rather than getting carried away by your standard conveyor, these materials find their way into the clean portion of the tank. Over time, they will build up against the system’s screens and create a clog. If you’re lucky, you’ll catch it before it creates too much of an issue and simply have to spend a day draining and clearing out the tank, an unpleasant and exhausting task. If you’re unlucky, the blockage may cause an overflow and you’ll have to clean up a coolant spill prior to draining and clearing the tank.
Fortunately, we offer a simple, plug-and-play solution that will eliminate this issue. Developed in conjunction with Jorgensen Conveyor and Filtration Solutions, Milltronics offers filtering chip conveyors for each of our machines. Designed to take tank size and coolant flow into account and tailored to each machine model, these solutions remove light chips and fine particulate to avoid potential clogs. The results can be dramatic.
With a standard chip conveyor, shops creating light chips and particulate material will typically need to manually clean their tank at least once per month. With a filtering chip conveyor, that frequency can drop to once per quarter. Given that draining and cleaning the tank usually takes a full day, you can instantly convert eight days per year of maintenance into eight days of production.
Additionally, if you’re interested in running lights-out production, a filtering chip conveyor dramatically improves your process reliability by removing the unpredictability of potential chip clogs.
Our line of filtering chip conveyors is available now and delivery time is just 6-8 weeks. They can be quickly and easily installed by your local Milltronics dealer, or by your own internal maintenance team. And, thanks to the amount of time they save, you can achieve a positive return on investment in as little as six months.
If you’re having problems with chip clogs or are having to clean your tank more than once per quarter, it’s worth taking the time to determine if a filtering chip conveyor is the answer. Contact us today at sales@milltronics.com to discuss if this solution is the right fit for your operations!
During his 17-plus years with Milltronics, Don Hammer has worked his way up from engineering to Vice President. You can reach him at hammerd@milltronics.com.
