Performance XP Series Vertical Machining Centers
[et_pb_section bb_built=”1″ admin_label=”section” transparent_background_fb=”default” _builder_version=”3.0.47″][et_pb_row admin_label=”row” _builder_version=”3.0.47″ background_size=”initial” background_position=”top_left” background_repeat=”repeat”][et_pb_column type=”4_4″][et_pb_text admin_label=”Text” _builder_version=”3.0.47″ background_size=”initial” background_position=”top_left” background_repeat=”repeat”]
Milltronics XP Series are #50 taper performance vertical machining centers designed for applications that need extra cutting power.  XP Series machines are built with either box ways or linear cross roller guides for rigidity, direct-coupled ballscrews for faster response and dual wound spindle motors for faster acc/dec and more torque.  Available with up to 35 hp for maximum metal removal, the XP Series features either geared head (VR4325XP) or heavy duty belt drive (VM5025XP & VM6030XP).  The XP Series also includes more standard features, such as a coolant ring and ralph lauren outlet washdown system, lift-up chip conveyor and height adjustment on the control.  The control is the latest 9000 Series control. View the full VM-XP Series Brochure. Click on the individual machine links below to see CNC machine pricing.
[/et_pb_text][/et_pb_column][/et_pb_row][/et_pb_section]
