At Milltronics, we are constantly refining our controls to simplify operation, shorten setup times, and provide features that reduce cycle times. The 9000-DGI Series control features 120 GB disk storage, 4GB memory, up to 10-times better graphic performance, mid-travel tactile keys, and an enlarged 15″ LCD touch screen. It’s a Windows®-based platform and offers all the user-friendly features that Milltronics CNC controls are known for, such as the G-code visualization screen.
With its conversational programming, on screen help, intuitive menus, color graphics, and prompted tool settings, the 9000-DGI CNC helps new operators get up to speed quickly. The 9000-DGI CNC makes it the one machine in the shop that everyone wants to operate.
The 9000-DGI CNC is packed with features that allow quick and confident operation of the CNC:
The 9000-DGI CNC allows operators to run parts programmed conversationally or tool paths generated by a CAM system. Coupled with a superfast motion control system, feature-packed CNC, and an interface designed to expedite setup and operation, the 9000-DGI CNC is the solution to helping your operator make parts faster and better.
ESSENTIALS | |
PROCESSOR | INTEL® CORE I5-3610ME |
INSTRUCTION SET | 64-BIT |
PERFORMANCE | |
NUMBER OF CORES | 2 |
PROCESSOR BASE FREQUENCY | 2.7 GHZ |
MAX TURBO FREQUENCY | 3.3 GHZ |
MEMORY SPECIFICATIONS | |
DATA STORAGE | 120 GB |
SYSTEM MEMORY INSTALLED | 4 GB |
GRAPHICS SPECIFICATIONS | |
GPU CORE SPEED | 600MHZ |
MEMORY | 1024 MB |
OPERATING SYSTEM | |
PRIMARY OS | WINDOWS® EMBEDDED 7 |
REAL TIME EXTENSION | INTERVALZERO RTX |
DISPLAY | |
SIZE | 15″ |
RESOLUTION | 1024 x 768 |
BACKLIGHT TYPE | LED |
TOUCHSCREEN | RESISTIVE |
OPERATOR PANEL | |
KEYPAD TYPE | ABS MID-TRAVEL WITH TACTILE
FEEDBACK |
DATA TRANSFER | USB PORTS AND ETHERNET CONNECTIVITY |
© 2024 Milltronics All Rights Reserved.
