1 General & 3 Specific Preventive Maintenance Tips
A machine going down is always an inconvenience. At best, it causes headaches and damages your profits. At worst, it can cost you a job or even a customer.
Despite the clear, negative impact of unexpected downtime, many shops skip easy steps that can keep it from happening. The overwhelming majority of problems encountered by manufacturers could be avoided via preventive maintenance. If you want to keep your machines running and productive, here are four tips to stay on track.
by Don Hammer - Vice President
Maintenance Schedule
#1 Follow your preventive maintenance schedule
Before we hit specific tips, it should be stressed that every item on the recommended preventive maintenance schedule provided by your machine tool builder is worth following. Milltronics carefully evaluates our equipment when developing these lists of tasks and the timelines for completing them. They are designed to maximize the productive life of your investment. When a new machine gets installed in your shop, reviewing the preventive maintenance portion of your machine documentation should be one of the first things you do. With that caveat out of the way, here are three commonly overlooked items that you should make sure to perform daily, monthly and annually.
#2 Check and record your lubrication levels daily
One of the most prevalent causes of machine downtime is failure of a lubrication line. This problem is both easy to spot and easy to miss. If you’re checking and tracking your levels daily, you’ll quickly notice a leak before it becomes a full-blown problem. But if you’re only topping off your lubrication when sensors warn you that it’s low, there’s a good chance you’ll overlook the small changes that precede a big problem. It takes less than 30 seconds to check the levels on your Milltronics machine. Make it part of your daily routine.
Check Lubrication
Inspect Spindle Belt
#3 Perform a monthly check of your spindle belt
For machines with a belt-driven spindle, failure of the belt during a cutting process can crash your spindle, leading to costly repairs and significant downtime. It’s extremely rare for a belt to fail suddenly, and a brief visual inspection will almost always give you advance notice that it’s time to take action. On Milltronics machines, checking the belt is as simple as removing two screws, opening the access door and quickly rotating the belt to check it for any signs of fraying. A monthly check is enough to dramatically reduce the chances of seriously damaging your machine.
#4 Annually inspect and clean your pump intakes
The pumps in your machine tool are designed for longevity, but their effective life will drop dramatically if they are overworked due to a reduced flow of coolant. Once a year, check the intakes on your pump. Use a wire brush to clear away any debris, or order and install a new filter if needed. The process is relatively fast and easy, but ignoring it can lead to substantial problems that are otherwise extremely difficult to spot until it’s too late.
If you have any general or specific questions about your machine’s recommended preventive maintenance schedule, don’t hesitate to reach out to us at service@milltronics.com. Additionally, while most of the associated tasks are fairly simple in execution, if you find that you don’t have the time to perform them yourself, we can likely assist you with a program via our dealer network!
During his 17-plus years with Milltronics, Don Hammer has worked his way up from engineering to Vice President. You can reach him at hammerd@milltronics.com.
